Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: Project 1775
  1. #11
    6,536
    Winch was never a problem for temp on any of my jeeps. I would bet it is just an older rad.
  2. #12
    Penis, AZ
    8,018
    Quote Originally Posted by fatbob309 View Post
    Yah, I ordered an OEM Spectra replacement one from RockAuto part CU2101 - was only $81 vs $97 from summit. Thought about the all aluminum, but I was looking at $330+ and would rather spend that on axles. If this one goes out in a year, Ill go the higher end route
  3. #13
    Penis, AZ
    8,018
    got the new radiator in, fairly straight forward swap. 10 and 11mm sockets is all you need
  4. #14
    Penis, AZ
    8,018
    TJ still wants to run hot on the freeway, starts warming up almost immediately - within a half mile of being on it.
    Ordered a new thermostat, will see if that helps. If not Ill probably just take it to Greg, gotta go to him anyway for the rear main seal leak. Once he has it Ill have him do a transmission drain/fill/inspection on it too and the brakes
  5. #15
    Penis, AZ
    8,018
    got a 180 tstat - it still got a touch over 210 on the freeway with AC on - Im guessing 215 or so - once I stopped I could hear water boiling in the overflow jug. I dunno why its happening, AC off on the freeway and it has no issues. Guess next thing to swap is the water pump
    but first its going to greg for the leaks
  6. #16
    Penis, AZ
    8,018
    thought Id update
    new waterpump, thermostat, radiator cap, hoses - still likes to run a bit warm on freeway
    also had it at AO - put in a front lockright because of this issue --- http://www.higherground4x4.com/forum...xle-loud-noise
  7. #17
    Penis, AZ
    8,018
    Ordered new rims since I didnt like the spacers and discount broke one of the lugs on em
    Got the Mickey Thompson sidebiter ones
  8. #18
    1,697
    I like em.
    hopefully they're heavier to keep that front end on the ground.
  9. #19
    Penis, AZ
    8,018
    lol yep
    Joe did mention that I need to set a limiting strap on the rear, the primary reason that drive shaft broke was the back flexed too much on that bounce
  10. #20
    Penis, AZ
    8,018
    ordered replacement back window for the soft top
    also picked up new JKS discos and an adapter for the 4wd linkage. Lost 4low on Moab most likely, it shifts into it but doesnt stay
