Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Building my own suppressor
    1,796
    Default Building my own suppressor
    I've been fascinated with the science of silencers. Hydrodynamics, CNC machines, CAD works, various metals, and fluidynamics.. all very interesting. So my friends and I been filing Form-1s with ATF and have been building various suppressors. This is my most recent build: I call it the "FART GUN". Silent, but Deadly...
    It started out as a Ruger MKII 5" tapered barrel. It's now a 6" integrally suppressed pistol with target sights, adjustable rear sights and scope base. CRAZY quiet. Pictures are worth a 1000 words, so Enjoy...
    Peoria, AZ
    7,976
    ooh thats pretty
    did the holes in the barrel mess with the rifling at all? any impact on accuracy?
    6,487
    Way cool. Those things are quiet to start I bet you dont hear much of anything.
    1,796
    Sounds like a baseball being bounced onto a cement floor. THUD!
    6,487
    Love it!
    Oct 2013
    25
    that is amazing. Im debating if i want to try my hand at a .22 suppressor. I dont have access to a lathe though so the tube part id have to outsource. It would be a SS/ aluminum monocore
    1,796
    http://www.sdtacticalarms.com/Hardware_c_8.html
    Start here. This company sells threaded tubes for "solvent traps". Their C-cell tubes are small so you can make a 22can pretty easily. The also sell endcaps and threaded caps. Their endcaps have no exit hole, so you can drill it to whatever diameter you need. A 22LR should be drilled with a 1/4" drill bit. I would go slightly larger so it will reduce the chance of the bullet strike.
    Make sure you have an approved Form-1 before you start drilling, assembling, or all that stuff. If you go monocore, then all you need is a mill. If you are going with aluminum, you may be able to do it with a dremel. You can have a machine shop do some of your lathe work, as long as they don't complete it. YOU should be the one to drill the hole(s) where the bullet will pass through.
    Oct 2013
    25
    Quote Originally Posted by 2ndchance View Post
    holy crap thats perfect. That has been my only hangup and didn't want to start asking around since people get weird about that stuff. thanks for the heads up. you sir are a gentleman and scholar.
    1,796
    Well, I built another one. Design is top secret but some pics are quite telling. It's a 30cal can for 300 blackout to 300 Win Mag. Custom machined. Mostly titanium.
  10. #10
    1,796
