Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Article: 1.25in Wheel Spacers - Nissan Xterra
    Default 1.25in Wheel Spacers - Nissan Xterra
    There's not a lot of info on adding spacers on a Nissan Xterra- well besides don't do it.
    As long as quality spacers are locked down though, the added exterior angle stress added on IFS suspension components is no more than using a smaller "correctly" backspaced wheel.
    My X is sporting the supercharger package rims. Even with 3 inches of suspension lift and a 2 inch body lift, 285/70/17 (33x11.50) is the tire size I'm stuck with unless I keep it on road. I had always wanted the tires to be pushed out a hair to increase the looks and stance. When I got the new BFG KM2's, I went ahead and threw on a set of spacers from RuggedRocksOffroad.com as well. I ordered the 1" but they were out so I tried the 1.25" and they ended up working out just fine. For safety's sake, I used red loctite since I didn't plan on taking them off anytime soon. The threading happened to be different on the spacer studs compared to the wheel studs, so I had to use the lugs inside the spacer. Thought shiny, they still fit just right, allowing the spacer to sit flush and not enough room to work themselves out if the loctite should fail.
    While the spacers looked fat before putting the wheel back on, after everything was buttoned up, the subtle look was just enough to look proportionally correct on the X. The most important part was that the wheels still stuffed just fine without any fender damage.
    Stuffed side room
    Opposite side:
    6,474
    sexy
    Thanks for the heads up on manufacturers
    4,731
    That is indeed sexy. That thing flexes pretty good You should post up some pictures of it since the new tires and such, not just one wheel
    My front end flex is camera shy
    May 2008
    75th and Bethany
    261
    looks good. i run spacers in the rear on mine and have had zero issues even doing the desert stuff. the biggest issue with spacers is after you initially put them on you need to go back and retorque them at least 2X after about 25-50miles each. by then everything had seated and your good. most spacers fail because they werent tight. looks good with the km2 though.
    Lost Industries
    Chris (Go Fast) Kredit - 602-616-5086
    Excellence Through Design
    Full Service Fab, Machining, and Mobile Welding
    8,519
    Quote Originally Posted by lostoffroad View Post
    hmmmm.. you don't say.
    Looks great Mike. Welcome to the spacer club. Great write up.
    1,664
    Quote Originally Posted by Skatchkins View Post
    Opposite side:
    That looks mean! any pics of it from the front so we can see the stance?
    Quote Originally Posted by sweathog View Post
    Oh you mean the Xterra.
    I need to get one with the new tires. Others here: http://www.flickr.com/photos/2822167...7622263779455/
  10. #10
    1,664
    LOL I did mean the xterra.
    ... although I did notice the flexed bulging bicep. very intimidating.
